Thread: Thermador built in not cooling
    Dec 2018
    Texas
    Default Thermador built in not cooling
    I have a built in fridge that is not cooling. I've replaced the compressor and drier (although I had to open the system after the install to fix a leak). Weighed in the factory spec charge. Unit cooled good for a few days and then stopped. Pulled the panel off the inside so I could see the evaporator. It is frosting at the top where the cap tube connects. The evap fan is running, pushing a lot of air. Unit has now been sitting a month and I tried it again, just started frosting in the same place on the evaporator (I re install the evap panal before I run the fridge btw). Any ideas?
    I'm thinking cut back an inch of cap tube near the evap and replace drier. Love to hear some other opinions.
    Are you a licensed refrigeration tech?
    Did you run a vacuum pump on it for about 30 minutes before you recharged it?
  1. VCSB483DSS Viking 48" built in not cooling
    By Jodo824 in forum Refrigerators & Freezers
    Last Post: August 9th, 2018, 01:20 AM
  2. Replies: 3
    Last Post: August 6th, 2018, 11:29 AM
    Last Post: July 5th, 2017, 10:08 AM
  4. Replies: 4
    Last Post: September 30th, 2015, 09:08 PM
  5. Replies: 5
    Last Post: June 15th, 2014, 08:04 AM
