Thread: Fivestar has oven issues
    Dec 2018
    Florida
    Default Fivestar has oven issues
    First post...Having issues with a Fivestar four burner gas oven/range. Basic problem is: When oven is plugged in, oven light comes on (even when oven dial not turned on), indicating the oven is heating but it is not. When the problem was first noticed, the oven burner was coming on and remaining on (almost as if it was stuck) but now it is not. Currently, when plugged in, the glow bar is glowing. Gas is getting to the unit as the stovetop burners will ignite manually but cannot use oven/broiler.
    Made a general service call and after ten minutes given a $700 quote to replace thermostat and safety valve. Iíve replaced the glow bar before but thinking that isnít the issue. Iíd appreciate the boardís thoughts and suggestions. The knowledge base here is amazing.
    Thermostat sounds right. I don't know about an oven safety valve. I've never heard of a "Fivestar" before. Is it commercial?
    Dec 2018
    Florida
    I believe FiveStar makes commercial models but this is a home model (TTN281-7BW, FiveStar 30", Multi-Tasker). I had never owned one but it was in the kitchen and came with the house and is a nice unit. The guy that came out called it a gas oven safety valve. I am certain I can replace the thermostat fairly easily and much less painfully than the $600 I was quoted.
    So a faulty thermostat could create a situation where the "oven on light" would be on, the oven was not heating(no flame), and the glowbar/igniter was glowing and yet not igniting? I'm guessing it is sort of a first steps and then assess sort of thing. Correct?
    Without any knowledge of the brand and model I can only give you general information. It could be the thermostat or maybe a control board if there is one.
  1. GE electric built-in oven issues
    By johnmr12 in forum GE/Hotpoint
    Last Post: February 22nd, 2015, 08:31 AM
  2. oven issues
    By noordmj in forum Frigidaire/Tappan/Electrolux
    Last Post: December 1st, 2012, 11:46 PM
  3. FiveStar 48" dual fuel range
    By Lomeo in forum Ranges/Ovens
    Last Post: September 11th, 2012, 10:53 AM
  4. Shutting off issues with GE gas oven
    By oasis2527 in forum GE/Hotpoint
    Last Post: January 25th, 2011, 09:13 PM
  5. Intermittent Issues with Oven
    By scoobydoodt in forum Whirlpool/Roper/Estate
    Last Post: May 14th, 2007, 03:24 PM
