Thread: Whirlpool Duet Dryer WED8300SB1 Won't Start
    Jan 2019
    San Antonio
    Default Whirlpool Duet Dryer WED8300SB1 Won't Start
    Model Number: WED8300SB1
    My dryer won't start. The thermal fuse checks out OK. The door switch checks out OK. So, believing it was the board (which I've had to resolder the relays several times over the years), I got a new control board and installed it today. Still won't start. The relays on the board click, but the dang thing will not start.
    Only other thought I have is to check to see if the motor has failed, but I'm not sure how to test that, and I'd rather not pull it that far apart if I don't have to.
    Appreciate any advice y'all can offer. I really can't afford a new dryer right now.
    Last edited by rickgburton; February 2nd, 2019 at 08:25 PM. Reason: corrected model number
    Recheck the thermal fuse. If the thermal fuse checks good use this diagram to make the following voltage measurements on the board:
Name:	Elec contrl.jpg
    P9-2 - P8-3 = 120 VAC constant
    P9-2 - P8-4 = 120 VAC with door closed
    P9-1 - P8-3 = 120 VAC when start button is pressed
    Jan 2019
    San Antonio
    Checked the thermal fuse again and it's now dead. I installed a jumper (switch) for testing voltages. All three check out as you specified, but it still won't start.
    OK then it sounds like the belt switch is bad (or the motor). Check the broken belt switch for continuity:
    279782 Broken Belt Switch Kit
    Jan 2019
    San Antonio
    Turns out it was repairman error. I tore it down to check the belt switch (cleaned and checked the switch while I was in there) and realized I had been checking the thermostat, not the thermal fuse.
    Thermal fuse is dead. I jumped the connection. It works. Fuse should arrive in a few days to finish the repair.
    Thanks for your help!
    That'll do it....keep us posted
  1. Whirlpool Duet Dryer Won't Start
    By Whortons in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 2nd, 2016, 07:52 AM
  2. Whirlpool Duet Dryer won't start
    By Ruots in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 2nd, 2014, 11:20 PM
  3. Whirlpool Duet Dryer will not start
    By silkysatin in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 4th, 2014, 12:48 PM
  4. Whirlpool Duet dryer won't start
    By Tara Gilliland in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 18th, 2013, 06:25 PM
  5. Whirlpool Duet Dryer won't start
    By swallace in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 14th, 2012, 03:07 PM
