Results 1 to 7 of 7
Thread: KERS303BWH1 Stove not pre heating
    Mar 2019
    Texas
    Default KERS303BWH1 Stove not pre heating
    Model Number: KERS303BWH1
    Brand: KitchenAid
    my 5 year old Kitchenaid Range will not pre heat properly, it heats up to only about 260 Degree in 1/2 Hr. instead of the set 350 Degree Temp. I have performed a " Hard Reboot" with no results. Called Customer Support for some Tech. Advise, the Agent told me to best buy a new Stove. This Stove will pre heat correctly in the Convection Cycle to 350 Degree, but not in the regular Bake Cycle. All other features on this Appliance work fine. Any Advise will be greatly appreciated, Thanks
    Last edited by Jake; March 28th, 2019 at 10:18 AM. Reason: Added complete model number
    Hi David,
    KERS303B is just a partial model number, we would need the complete model number.
    Here's the results I get:
    KERS303BBL0
    KERS303BBL1
    KERS303BSS0
    KERS303BSS1
    KERS303BWH0
    KERS303BWH1
    So when its preheating the display only reads 260 degrees and stops there? Or do you have a oven thermometer inside the oven telling you this?
    It might be best to purchase your own Digital Multimeter. They are not that expensive and come in handy for a lot more than just appliance repair.
    This one is less than $20 and will also measure oven and refrigerator/freezer temperatures:
    Digital Multimeter DM10T
    When did this problem start happening?
    Mar 2019
    Texas
    thank you, Jake. Model is KERS303BWH1. I do have a digital Multimeter without the Temperature Probe, also a Laser Temp probe which is very accurate currently testing the pre heat temperature and will respond later.
    just finished retesting the pre heat temp. on the Bake cycle, after 25 minutes the temp on the stove showed 265 F., inside with the Oven Thermometer it read 245F, a check with the Laser Probe read 248F.
    Mar 2019
    Texas
    please advise
    Got it David!
    Sounds like possibly the main control board is the problem: WPW10340695 Electronic Control Board
    Mar 2019
    Texas
    thank you Jake, guess I'll just buy a new Stove
    Wait David,
    I just noticed your bake element is hidden, and on those hidden ones those can wear out much more quickly than non-hidden ones.
    So first Unplug the range from the wall, then remove the bottom access panel in your oven and see if you notice if your bake element is broken or cracked. If you don't notice it cracked or broken, then ohm test it with a multimeter.
    Here's the bake element for your model:
    Bake Element W10779716
    When you click the part link to your bake element you will see a video on how to access it.
    Here's the ohm testing video: Bake/Broil Element Ohm Testing Video
  1. LRE30453ST/01 LG Stove Not Heating to set Temperature
    By zmjames6 in forum Ranges/Ovens
    Last Post: March 12th, 2015, 12:00 PM
  2. heating element in stove stays on
    By fullbloodedmutt in forum Sears Kenmore
    Last Post: September 1st, 2013, 10:07 PM
    Last Post: June 15th, 2012, 01:41 PM
  4. over the stove micro not heating
    By mag in forum Maytag/Jenn-Air/Magic Chef
    Last Post: November 19th, 2011, 09:24 PM
