Thread: GDF520PSF4SS GE Dishwasher fills with water but won't spray or move arms
    Apr 2019
    Austin, TX
    Default GDF520PSF4SS GE Dishwasher fills with water but won't spray or move arms
    Model Number: GDF520PSF4SS
    Brand: GE
    Hello,
    I'm having a problem with my dishwasher I was hoping someone might be able to help me with.
    Currently, it will fill with water and then just sit there, it seems to heat up, the soap door opens and it leaks down the door. then it drains and does it's heat dry stage. but the arms never spray any water or anything.
    so far i've checked and cleaned the float switch, the arms, all the filters. I replaced a faulty water inlet valve, and removed the motor and cleaned some hair out of the impeller blade thing. i checked the amps on it and it seemed fine. i think it was about 1250. (sorry, i'm not great at this mechanical stuff).
    occasionally, after i turn off the power, take things apart and reassemble them, the dishwasher will sometimes work fine for one to two cycles. then the arms just stop working again.
    I feel like i've tried everything recommended online for this model so far, but i might have missed something.
    I was wondering if anyone had any suggestions or other steps i could maybe take.
    any help would be greatly appreciated.
    thank you very much!
    Jeff
    Wash motor running?
    Wash motor running?
    Arms turn ok by hand and are not jamming/binding?
    When they stop....is the wash motor working, water level ok?
    http://www.applianceaid.com/
    I thought my dryer was shrinking my clothing.....turns out is was the refrigerator!
    Apr 2019
    Austin, TX
    Hey Jeff,
    thanks for your quick response!
    I'm not entirely sure how to tell if the wash motor is running?
    but yes, the arms turn fine if i move them by hand. i also tried taking them out and running it with no arms, and no water came out of the holes where they attach.
    and the water level seems fine. it fills about an inch or two, to right below the heating element.
    it's like the next step in the wash cycle just isn't turning on after it fills with water.
    That should be good.
    Can't hear it?
    Remove lower from panal for a better listen then?
    Apr 2019
    Austin, TX
    ok, yeah, once it fills with water, i don't hear anything.
    does that mean the motor's dead?
    If the motor is getting power but not running, yes bad motor.
    If not getting power when it should be running, control not sending power and likely bad.
    A couple of items we are now changing together for poor or no washing...
ID:	42810 P1A Wash Pump
ID:	42811 Diverter Asm Kit
    Remember you or someone else need to check for power to the wash motor before doing anything else.
    Apr 2019
    Austin, TX
    Thanks man!
    what's the best way to check that power is getting to the motor?
    Volt meter.
ID:	42817 Digital Multimeter is an economical solution to your everyday electrical & temperature measurement needs.
    Appears to only be 2 wires at the motor. 110-120 volts AC is normal.
    Apr 2019
    Austin, TX
    Hey man,
    sorry i haven't been able to get back to this for a few days.
    so to test the wires at the motor. should the dishwasher be plugged in? and do i need to have my multimeter set to any specific setting? (sorry, i've never tested for voltage before)
    You might be best to call someone in...just to be safe.
    Yes.
    Enough to check 120 volts AC.
    jeff
  1. FGHD2433KF1 Dishwasher spray arms don't move
    By Riggs in forum Frigidaire/Electrolux
    Last Post: July 6th, 2018, 10:26 AM
  2. Replies: 3
    Last Post: October 17th, 2017, 08:33 AM
  3. Dishwasher not sending water through spray arms
    By Brett Anderson in forum Whirlpool/Roper/Estate
    Last Post: September 22nd, 2015, 09:34 PM
  4. Replies: 5
    Last Post: May 14th, 2014, 08:30 PM
  5. WP QuietPartnerIII - Fills, but nothing comes out spray arms
    By HFMDave in forum Whirlpool/Roper/Estate
    Last Post: August 9th, 2009, 05:30 PM
