Thread: JMC1116 Jenn-Air Microwave shuts down rather randomly, happens when a lot of steam in oven
    May 2019
    Albuquerque
    Thumbs down JMC1116 Jenn-Air Microwave shuts down rather randomly, happens when a lot of steam in oven
    Model Number: JMC1116
    Brand: Jenn-Air
    I think title says it all. When cooking various plates, especially if a prolonged cooking time, greater than couple minutes (but not necessarily on high power) the unit will completely shut down. This has also happened using a preset menu. The display will go dark, like there is no power. Opening the door and usually there is a lot of steam in the oven. Unit will come back after sitting for 1/2 - 1 hour (or more), display will come back.
    I tried unplugging unit but that does not seem to decrease the time unit must sit to recover. Is there a sensor that has gone over active, or the board that the sensor plugs into decidedly over ambitious in completely shutting the unit off. This is a real pain when my wife has a few friends over for game night, and all the ladies have a dish that needs heating, after the unit turns off, no one else can heat their dish.
    It wouldn't be so bad if the unit just stopped cooking and you could just blow out the oven to remove the steam, but the display going out says some board is shutting the whole unit off. When the unit stays plugged in, when it comes back to life the clock needs to be reset.
    You posted the Age as Less than 1 year old, is that correct? If so you have a full 1 year warranty on it from Jenn-Air.
    1-800-JENNAIR (1-800-536-6247)
    May 2019
    Albuquerque
    Sorry about the age specification, Its beyond the 1 year warranty. I wanted to note that it was nowhere near 5 years old. I seemly can't find receipt (odd as we have a folder for major appliance receipts). I just talked to store where I bought it, and that was January 2018, so its out of warranty.
    So can you help me diagnose this? Is there a board I can replace?
    Got it!
    Yes, it sounds like the control board is bad.
    But the control board is not listed on the parts diagram, which is very odd.
    Unplug the microwave and remove the control board and see if there is a part number on it.
    If so, post it here.
    May 2019
    Albuquerque
    Sorry for the delay.
    There are two boards. The first 2.5 x 6 inches is right behind the keypad/display. It looks like the display is mounted directly to this board and a ribbon cable to the keypad.
    It is silk screened and marked Midea VER:M1.31 , below that, 2016-12-19, which is probably the date. Off to the right: MD1001LB
    Please see uploaded close up image of the top of this controller board, and an image of the overall board. I can probably get a better image if I remove all connectors and/or remove the board.
    On the bottom, E173873. There is a sloppy ink stamp 11711157 which is probably the serial number.
    There is a second board, ~ 1.5 x 2.5 inches, where both the incoming ~AC lines come into, and its output feeds the other components (load to looks like thermal switches and door switch in series, neutral to above board, I haven't done a complete wire trace). It just has a fuse, couple capacitors and a small torrid transformer. It seems to be a filter (either for spikes on the line, or to reduce noise to other items on the AC circuit.)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	43218   Click image for larger version.
    Nope, those are not the part numbers I need.
    You'll likely need to take the microwave to a Jenn-Air service center where they can fix it for you. Contact Jenn-Air and ask them where to take it to for repair.
  1. Replies: 10
    Last Post: December 20th, 2018, 08:19 PM
  2. CGS990SET7SS GE Cafe Range lower oven randomly shuts off
    By Mike Mendoza in forum GE/Hotpoint
    Last Post: November 6th, 2018, 01:10 AM
  3. Replies: 2
    Last Post: January 15th, 2017, 11:06 AM
  4. Jenn-Air SVE47600 "Locked" light on randomly and door locks randomly.
    By cabinetman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 24th, 2014, 11:40 AM
  5. Jenn Air oven shuts off.
    By nyrend in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 28th, 2007, 02:19 PM
