Thread: GE - GDF520PSF2SS wont start...tried a few things already
    May 2019
    MD
    Default GE - GDF520PSF2SS wont start...tried a few things already
    Model Number: GDF520PSF2SS
    Brand: GE
    Hello all,
    Unit is 5 years old. Started out not filling up and pulling the detergent out of the holder. Pulled the float switch out and cleaned it with vinegar and peroxide. Freed up the switch it was stuck.
    After that it worked a few times then the start button wouldnt start the unit.
    I replaced the door latch switch no change.
    Ive replaced the interface control panel with no change.
    I'm not sure how to diagnose it further. Holding start and select cycle for 5 seconds makes all LEDs blink 9 times then the lock controls light illuminates.
    The only thing left to change is the unit control board?
    I'm wondering if I should just buy another unit...
    Thank you!
    Corey
    Hi Corey,
    Open the control board cover and check the Service LED on the control board. If the Service LED is blinking, count the number of blinks between pauses. If the LED is not lit replace the control board.
    Control Board WD21X22276
    Here's the video that show you how to remove the cover to access the main control board, and Service LED on it: Main control board access video
  1. 110.85861400 Wont start, wont run, wont heat.
    By boodab71 in forum Sears Kenmore
    Last Post: October 27th, 2017, 12:00 PM
  2. Maytag neptune gas dryer - wont start, start/pause light keeps blinking
    By jason Blanton in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 1st, 2015, 10:55 PM
  3. GE GDF520PSF2SS won't fill
    By hrt jr in forum GE/Hotpoint
    Last Post: January 29th, 2015, 07:20 AM
  4. Replies: 1
    Last Post: January 28th, 2013, 10:52 PM
  5. FIXED: Kenmore Model 665.17593200 wont drain and wont start
    By Homefixerguy in forum Sears Kenmore
    Last Post: October 22nd, 2011, 06:29 PM
