Thread: KFIS27CXMS0 Kitchenaid Ice Maker works, then stops working
    Jul 2016
    memphis
    Default KFIS27CXMS0 Kitchenaid Ice Maker works, then stops working
    Model Number: KFIS27CXMS0
    Brand: KitchenAid
    I'm a diyer with an ice maker issue. We recently bought this refrig second hand and the seller told us the ice maker would make ice but wouldn't dump it. I bought a new ice maker and it's worked fine for 5 wks. Yesterday it stopped dumping ice again leading me to believe the original ice maker was ok and the problem lies elsewhere.
    I turned the ice maker off last night, back on this morn, then we left and when we returned I checked and it had dumped one load of cubes. I checked the ice maker and it has another load of frozen cubes. That was three hrs ago and it hasn't dumped that load yet. I know there's a light sensor in the ice bucket and it's lite.
    I also know the two door light switches tie into the ice maker but the interior lights work fine. What am I missing? Is there a circuit board that controls the ice maker? If so, what are the chances it's bad and where is it located? I looked at schematics online and it shows a dispenser board but it's not specific so I assume that's for the thru the door water/ice dispensers. It making ice is no problem; dumping ice is. Any ideas will be GREATLY appreciated.
    Do you have a thermometer you can put inside the ice maker compartment? It has to always be 16 degrees or lower for the ice maker to cycle that ice out into your ice container on a continual basis.
    Also do you hear the ice maker fan running in the ice maker compartment?
    What's the part number of the ice maker you replaced? Did you put the old ice maker back in place to see if it would dump any ice at all?
    Here's the ice maker for your model:
    WPW10122559 Icemaker
    Here's the tech. data sheet for your model: https://drive.google.com/open?id=0Bz...W95UXY4Z2Eyem8
    On the main control board P3-4 which is the live side to the ice maker, then P1-2 is the neutral side to the ice maker.
  1. Replies: 5
    Last Post: June 7th, 2018, 09:01 PM
  2. Replies: 2
    Last Post: January 28th, 2014, 04:49 PM
  3. FIXED: Default kenmore elite ice maker works & stops, requires reset, sometimes works slow
    By Michael Leonard Woodcock in forum Sears Kenmore
    Last Post: July 15th, 2012, 01:09 PM
  4. FIXED: Refrigerator stops working then works fine next day ?
    By mbay14 in forum Whirlpool/Roper/Estate
    Last Post: June 10th, 2012, 08:51 PM
  5. Ice Maker - works once the stops
    By Paffer66 in forum Sears Kenmore
    Last Post: March 11th, 2011, 01:18 AM
