Thread: No lights - No Power IKEA Dishwasher IUD9500WX2 Whirlpool?
    Oct 2006
    texas
    Default No lights - No Power IKEA Dishwasher IUD9500WX2 Whirlpool?
    Model Number: IUD9500WX2
    Hello!
    Based on reading here and other sources across the internet I believe my Mom's dishwasher blew the thermal fuse. An IKEA Dishwasher model IUD9500WX2.
    The symptom is no lights on the controls located on the top of the door. There is also no response when pressing them. Normally when the door is opened pressing the start button causes the lights to turn on under the respective cycles and it starts once you close the door in <3 seconds.
    After checking the breaker, (not tripped) it seems most likely this is the thermal fuse. I have a hard time replacing a thermal fuse without knowing what caused the fault/overheating? I think I read somewhere these just fail overtime, is that accurate? Also, does all the power supplying the dishwasher go through this fuse? Heating element, pump motor, drain motor?? I would think it would be wise to at least check continuity/resistance on these motors. Maybe also the control board??
    Does anyone know what the typical resistance readings are for drain motor, pump motor, heating element? (Obviously, if there is an open it's self explanatory.)
    Much thanks for any assistance!
    -Anthony
    It wears out more often than high current or high temperature wears it out. Actually that's what wears it out. The constant heating and cooling of the bi-metal wears it out. I understand what you're asking, if a component failed or is failing and that's what caused it to go. That rarely happens believe it or not. It's been updated to a more HD thermostat and comes with new wires. Be sure to use them. The tech sheet located behind the lower toe plate will have the resistance values for the components and voltage/amp values.
    Thermal Fuse W10258275
    Oct 2006
    texas
    Thanks Rick! As I suspected, these are clearly different from a dryer's thermal fuse, as an example. Appreciate your time and info. And I forgot about the tech sheet... appreciate that reminder!
    Anytime!
  1. FIXED: Ikea Whirlpool IUD9500WX4 No Lights
    By Dan Bloch in forum Whirlpool/Roper/Estate
    Last Post: September 26th, 2018, 01:25 AM
  2. Anyone heard of a Renlig dishwasher from IKEA?
    By jennjoom in forum General Appliance Chat
    Last Post: July 25th, 2018, 02:17 PM
  3. Replies: 4
    Last Post: April 25th, 2017, 06:00 PM
  4. Ikea/Whirlpool just stopped... no lights.
    By SCR2000 in forum Whirlpool/Roper/Estate
    Last Post: June 11th, 2010, 01:44 PM
  5. Whirlpool GU1200 Dishwasher-No Power or Lights
    By Jason in forum Whirlpool/Roper/Estate
    Last Post: October 3rd, 2005, 01:37 PM
