FIXED 721.69129010 Burning smell. Dead
Vintage
SE PA
October 2012
Serial 210TA01356
Burning electrical smell. Then it worked four times at 8 minutes each to heat milk for yoghurt making. Then disinfected two dish cloths at 1 minute each. Then it was completely dead— no light inside, no clock, didn't run. Five minutes later I noticed the ":" only was on for the clock. I warmed up a cup of coffee for one minute and it worked fine. I took it out and now it has been completely dead— no interior light, no clock LED, doesn't run. Repairable?
Sometimes one of the wires going to a thermostat or fuse board inside would loosen and melt causing similier issues. I'd check for that for sure. Check the plug and wall outlet as well. Outer shell will come off to inspect ( power off first ).
Vintage
SE PA
Thanks. Yes, I had checked the outlet. Everything inside looks fine, except possibly this one connector on top. Is this normal?
Jeff may have missed you last posts.
Click on his name then a popup box will open, then click Private Message to refer him back to your thread here.
Vintage
SE PA
It is working at the moment, so I wouldn't be able to check that. The past two days it was worked a bit, then not, and now working again. Does that point toward anything?
Vintage
SE PA
It has continued to work for a bit then shut off. Since yesterday it happens almost every time we use it. It generally dies just after it finishes running, the LED screen goes dark, the light inside is not on when the door is open and it does not run. Then about an hour later we will hear a beep sound and the semi-colon is lit on the screen and all is well. Clues?
Did you repair the wire and thermostat?
I have also seen fuse heat up and quit....cool down and reworks.
I have also seen fuse holders heat up and quit....cool down and reworks.
Vintage
SE PA
It works when I use a wire to bypass the thermostat. What would cause the connector to melt like that (pic above)?
Vintage
SE PA
Is this thermostat used to somehow measure the temperature of the food and then help regulate the running time, or is it a safety feature. In other words, is it okay to bypass it?
No.
No.
Yes.
Then that would have to be addressed for sure!
A loose connection. It gets hot and hotter until it burns off.
Vintage
SE PA
Getting that wretched burned wire smell again, but it hasn't stopped working like five months ago before I replaced the thermostat. I took off the cover and am not seeing anything brown or melted. Suggestions?
If you can't see any burnt or bad connectors....let it go until something quits.
You checked all door switches, all thermostats, board connections, magnetron connections, power cord, etc?
Vintage
SE PA
Okay, I will keep going. I may try it with the cover off. Maybe I can locate the source easier.
Vintage
SE PA
The connector with the black and brown wires started melting when I tried heating a cup of coffee. Suggestions?
That is the 120 volt input for the transformer.....good catch! New wire terminal time and cut off the old burnt one.
