FIXED 721.69129010 Kenmore Microwave - Runs when door opens
Vintage
SE PA
When door is opened the light comes on and it runs, including plate turning. It stops again when door is closed. It does not run when trying to run it with door closed, although the light comes on and timer counts down.
Interestingly, at around the same time we noticed our Amana range was flashing F1. I posted that problem in that forum.
Thanks for any counsel!
Sorry, we must of missed your thread by accident.
Glad to hear the new lower door switch fixed it.(y)
Your Kenmore 721 model is made by LG.
Here's the lower door switch for your model, in case others need it too:
Vintage
SE PA
Thanks. This was the closest I found at the local hardware store and it worked fine.
Ok sounds good.:)
