721.80012401 Kenmore Loud humming noise no heat
quatin
florida
I removed the cabinet and found the trouble shooting manual folded up in the panel. I discharged the HV capacitor, but everything seemed to measure ok. From googling, everything points to the magnetron or diode, but I can't see anything wrong. I even removed the magnetron and visually inspected for cracks in the magnet or antenna.
Things done so far:
Primary transformer coils: low ohmage
Primary transformer coil to chassis: open
2ndary coil to chassis: 90ohmish
filament coil: low ohmage
filament coil to chassis: open
Magnetron terminals: 1.5 ohm (that's as low as my MM measures)
Mangetron terminal to chassis: open
Capacitor terminals to chassis: open
Capacitor + terminal to - terminal: starts at 2Megaohms and charges to 10Megaohms
Diode: I put a 12V battery in series, but with a MM closing the loop so it's high resistance. Measured across the anode and cathode: 8.4V. Flipped polarity of battery, measured 0V
Measured across all the resistors in the filter circuit board.
Everything seemed fine to me. I'm not sure what else to check here.
