721.80523500 Fuse blown
red1958
Puerto Rico
I have the 250 V 20A fuse blown after a power outage. Replace the fuse and it still blown everytime I hit the start button. This is what I have done so far:
1- Disconnect fan, blower and Magnetrón. Fuse blown.
2. Connect all ítems back ( except the Magnetrón ). Fuse blown.
3 - Disconnect HV transformer. Fuse OK.
4 - Check diode and capacitor. Seems to be OK.
5 - Connect HV transformer. Fuse blown.
6 - Disconnect diode and capacitor. Fuse OK
7 - All steps from 2 are with the Magnetrón disconnected.
8 - All lights, fan, blower, display Works fine if I don't hit the start button.
Any idea about why the fuse is blowing? ( I am using a fast blo fuse. Do not have any time delay fuse.) I am thinking about replacing the diode and capacitor but am not sure if that will solve the problen. Thanks for your help.
Best Regards
red1958
Puerto Rico
Hi Jeff:
I found a capacitor and a diode on my garage from an old Microwave but have not installed them yet to test if they solve the problem. As soon as I have a chance, I will work on it and let you know if the problem is solved or if I need to buy any other part. Thanks for your reply.
Keep us posted when you can.
red1958
Puerto Rico
Hi Jeff:
I replaced the capacitor with one with almost the same spec ( .91 mF instead of 1 mF ) and the microwave start working again. Will it makes any difference having a slighty different capacitor installed ? Will it affect the performance of the microwave? Thanks again for your help.
Yes, yes.
I try to not go more than 5-10% difference.
I might sub a .95 for an 1
.91 is a bit low.
