721.86002 Low voltage transformer test?
Zorky
Ohio
Less than 1 year
How can I test the low voltage transformer? Should I have voltage on all the output lines? I have 120 on the main ones and 0 on the smaller gauge wires that go to the PCB on a 6 pin connector. Pretty sure I located my problem. PCB is giving the low voltage transformer 120v and its not putting out anything. I need to find part number EBJ56679201
Zorky
Ohio
I also tried to measure resistance between the primary and secondary coil and getting infinity. Assuming a open winding is bad right?
Zorky
Ohio
If they show no ohms then it is bad? Also its ok if its backordered I don't need it right away. I just want to make sure this thing is bad before buying one.
The primary and any/all secondary windings should show continuity.
