FIXED 721.86002 Power surge and now dead
Zorky
Ohio
This is a brand new unit but 3 years old. Was a display in a model home and never even powered on until we got it. Long story short. We had a severe power surge 3 days after owning this due to a power company issue. It is completely dead. I am knowledgeable on electronics and have the unit disassembled. Everything was discharged. Capacitor is a 1.05uF and test good. Diode test open circuit. Thermal and magnetron fuse test good. I have 120 hitting the input of the transformer. I am suspecting the transformer is bad. The only ohm reading I am getting is on the secondary winding of 90ohms. Getting OL on primary winding and filament. I don't really know how to test the board. I am not seeing anything blown or burnt on the panel board. The fuse on the noise filter assembly never blew. Could a transformer blow without the 20a fuse on the noise board blowing? Does the transformer always produce voltage when the microwave is plugged in?
"Completely dead" means no lights, no display, no sounds. However you're saying you have 120 VAC at the primary windings on the high voltage transformer?? Can't be.
Zorky
Ohio
Not sure about primary winding, I had 120v at the input wires feeding HV transformer. Found the PCB is bad. Traced power from the cord clear through the PCB and I had 120v hitting the input of the HV transformer. I did not have the HV transformer plugged in for obvious reason. I don't know if the primary winding had voltage. I know I have 120v hitting the input of the HV transformer. Unit is completely dead. No noises, lights, display or anything.
Zorky
Ohio
Not sure how to mark this thread as fixed. But this issue I had ended up being the low voltage transformer. Had voltage up to and passing through the control board to the input of the low voltage transformer. Had no power coming back to the control board on the 6 pin connector from the low voltage transformer which is what actually fires up the control board functions. Coils appeared to be open windings.
You HIGH VOLTAGE transformer here: 6170W1D100G
I see no low voltage transformer on this model.
Zorky
Ohio
This does for sure has a LV transformer. Part number EBJ56679201. This sits directly below the noise filter board assembly and fuse.
