Results 1 to 6 of 6
Thread: kenmore 80 series electric dryer-heat but will not dry
    Jul 2005
    Post imported post
    I have a electric series 80 dryer and it runs and heats up but will not dry clothes. I cleaned out the entiredryer ventand lint filter-
    any ideas-Thanks
    Jason
    Oct 2004
    Post imported post
    jtreiger wrote:
    I have a electric dryer and it runs and heats up but will not dry clothes. I cleaned out the entiredryer ventand lint filter-
    Did you try running it with the vent totally removed for a load or two so see if it dried any better. If it did it would usually indicate the vent is (at least part of) the problem... even if it isn't plugged. You can read about dryer venting at the following link:
    LINK > How long can my dryer vent be?
    It would also help if you posted the dryer's complete model number ("series 80" isn't it) so we can see what components it uses which might be responsible for problems. You can find tips for locating the model and serial number identification tag on your appliances at this link:
    LINK > Model Number Tag Search
    JFYI
    Appliance411.com
    =D~~~~~~
    Jul 2005
    Post imported post
    I will get the serial # and exact model #. I did not try it without the vent for a full loadbecause it worked for 2 yrs without any problems than all of a sudden it quit drying clothes. I did run it and felt the exhaust coming out of the back but it did not seem to be blowing that hard. I took the back of and cleaned out the lint filter all the way but it was the same. -Thanks
    Jul 2005
    Post imported post
    The model # 110.62872101
    Serial# ml5202007
    Kenmore 80 series electric dryer, heavy duty, quiet pak, extra large capacity.
    It heats up but will not dry. I cleaned out the entire vent, about 15 feet, to the roof.
    If the cover of the exhaust fan and channel out the back are not sealed airtright, will it not force enough air out theback to dry clothes. The foam gasket is a little messed up.How hard should the ehaust be coming out? Any help or ideas appreciated.
    Jason
    Jan 2005
    Moorpark (via Motherwell, Scotland), California, USA
    Post imported post
    That won't help...these machines are not good at pushing upwards, and will not exhaust moisture properly. Like Dan said, run it without the vent, you'll almost certainly see an improvement.
    Oct 2004
    Post imported post
    What hind of material? how many elbows?? As Mac, said, pushing straight up may be a problem in itself. You may need to alter the venting to get it to dry properly. Has it ever worked acceptable in the same installation?
    One make's installation instructions states, "The system back pressure MUST NOT be higher than 0.75 inches of water column. If the system back pressure is less than [that], the system is acceptable. If the manometer reading is higher, the system is too restrictive and the installation is unacceptable."
    I don't suppose you have a manometer hanging around to test with?
    Appliance411.com
    =D~~~~~~
  1. Kenmore Series 90 Electric Dryer No Heat ?!?
    By parttimerz in forum Sears Kenmore
    Last Post: December 30th, 2012, 03:14 AM
  2. Kenmore Electric dryer series 90 shuts off
    By tomkat in forum Sears Kenmore
    Last Post: September 30th, 2006, 08:52 AM
  3. Kenmore Elite electric dryer no heat...
    By route62 in forum Sears Kenmore
    Last Post: January 10th, 2006, 06:40 PM
  4. Kenmore 70 Series Electric Dryer will Not Start
    By planz in forum Sears Kenmore
    Last Post: December 4th, 2005, 08:18 PM
  5. Replies: 6
    Last Post: May 4th, 2005, 09:48 AM
