790.45003801 Kenmore induction range elements inoperative
rossjonj
At first it took repeated attempts to turn the elements on but now they wont turn on at all. all center panel functions work (oven, warmer tray, light, etc). please advise if there is a specific thread here.
I'm not familiar with these induction models.
But this model is similar to yours:
It may be the filter board on yours that failed too:
These boards are very expensive.
rossjonj
Thanks, just seems odd that everything else except the range elements work. Tried replacing the range control board, part #316442056. No difference.
rossjonj
Sear Parts direct is suggesting that the oven temp sensor, part number 316217002, needs to be replaced. Does this make sense to you? Thanks.
Possibly, but you will need to ohm test it first.
You can ohm test the oven temperature sensor probe with a multimeter, normal reading would be between 1050-1100 ohms at room temperature. Turn your breaker off first to your oven before you do anything.
To get to the oven temperature sensor you would need to pull your range out(you may need someone to help you, as these are very heavy) and take off the back access panel, then you will see the plastic connector that unsnaps to it.
Here's the oven temperature sensor probe for your model:
Temperature Sensor 316217002
rossjonj
thanks. i found the same video. removed the sensor.got no reading at all but going over to my brother's house tonight. b.a. in electrical engineering. hopefully he can corroborate my reading. again kinda funny that the oven works but not the elements.
You need to make sure you have fresh batteries in your meter.:)
