rich.theil
- 790.48133800
- Sears Kenmore
- More than 10 years
I’ve got a Kenmore Elite double oven (790.48133800) that runs normally until it randomly decides to shut itself off - usually after running for about 20 or 30 minutes (it varies and seems to take a little time before it shuts off). Notably, it does not trip the breaker and it will not work again until some time has passed (even if I manually flip the breaker off and back on as a “hard reset”).
I’ve taken the oven out of the wall to examine it.
I’ve examined the two control boards and I don’t see any popped capacitors or burn marks. I checked both sides of one board, but only the top of the relay board (it’s more challenging to remove).
I’ve also removed the back panels from the oven and found one small burn mark - about the size of a penny (see image of sheet metal). The burn mark corresponds to the wires for the upper oven’s top heating element.
I suspect the burn mark came about because the heating element wire made contact with the sheet metal. I think this happened because over the last 10+ years, we’ve used that upper oven quite a bit and I think the heating element wire coming into contact with the sheet metal is causing a short and shutting down the electronics.
The other two photos show the difference in the angle of the connection between the upper heating element for the top oven and the upper heating element for the bottom oven.
I bent the wires down for the top oven as a way to eliminate this particular problem.
My questions
Rich
My questions
- Has anyone seen this before?
- Is it likely the cause or do you think I have something else going on. Notably, there is one thing that casts doubt on this being the likely cause…we have this problem whether we are using the top oven or the bottom oven. I would think it would only happen if the top oven were in use.
- Thoughts on what it could be?
Rich
