790.48173000 Kenmore Elite - Upper Oven Broiler Element Problem
rjt4re
With the upper oven set to Bake, after the broiler element comes on during preheat it will not go off until the oven is turned off. Oven initially displayed the F10 error code for run-away heating when left unattended. If oven is allowed to cool down, this same cycle will occur. However if you immediately try to turn the oven on Bake again without it cooling down the broiler element will come on almost right away. From all I've been able to read on this forum it sounds like a relay control board problem. But since there is a twist I thought I'd put the scenario out here for a more informed opinion. Also, does the entire oven need to come out to replace the board? PS. The lower oven functions as it should.
Added complete model number
790.4817 is just a partial model number, we would need the complete model number.
Click here: Appliance Parts
rjt4re
Thought the balance was just the color. Looked on oven, here’s the full number 790.48173000
Thanks! No, just the last digit in the model number is the color.:)
Yes, the problem is your relay board.
Here's the relay board for your model you can order:
316443936 Board
