790.48779900 Kenmore Double oven loses complete power
Ivan1985
Illinois
Hello hoping someone can help me. After my troubleshooting I believe this part could be my issue ?”Electrolux oven relay board” Kenmore double oven model 790.48779900. I set to 400 degrees & couple times already it just completely shuts off loses power totally dead no display as well for about 10-15 min then power comes back to unit & I can turn back on continue what I was baking.Could this part be the issue on my oven? Not sure if this common symptom for this part going bad.
Ivan
Disconnect the connectors on the board one at a time then reconnect them. Check the metal pins in the connectors and make sure they're not backing out of the connector. When it loses power again measure the voltage across DLB-IN and L1 (220 VAC) Measure the voltage across J1-1 and J1-3 (120 VAC). If the voltage is correct replace the relay board:
Relay Board 316443913
