FIXED 790.48803100 F84 Code - Light does not come on in microwave
Loinest76
Louisiana
F84 code microwave oven not working, Light does not come on in microwave I checked all fuses in microwave all good door switches all good also and I checked low voltage transformer also checks good not sure what electronic control is bad there is a main relay board a display board and the microwave electronic boars
Check for 120 VAC across J1-1 and J1-2 on the relay board. I'll check for the wiring diagram. If you have yours can you post a copy?
Loinest76
Louisiana
Do you think it’s a problem with the microwave oven board or the relay board I check the low-voltage transformer that plugs into the microwave board and it ohms out good
Loinest76
Louisiana
I found a blown Buss 20 amp external fuse have it on order not sure what caused it to blow
Rick is under the weather, hopefully he will be back soon.
Let us know how it goes after you replace that fuse.
Loinest76
Louisiana
This fuse Is part of the microwave oven combo the problem was a blown fuse and a bad door interlock door switch
