790.79363405 Kenmore range door issue
magda
NJ
Hi, so I moved into apt that have a range that needed some serious cleaning. I decided to take the glass apart to clean it inside. Once I put it back together I noticed a gap between the glass and outside frame (see pics). I'm not sure if that was like this before and I don't know if this is ok. I didn't touch anything in the stainless frame except 2 screws on top to take the handle off. The bottom had no screws or glue that would make it stick to the glass. The glass was suspended using tension brackets so I know I put it back in the right spot. To me it looks like the stainless frame is curved on the bottom, so it doesn't touch the glass, but I didn't use any force on that part, so I'm clueless. Thanks in advance.
Chris112
earth
I don't think there should be gap. I ordered a new outer glass for my mother's Kenmore oven....and will let you know if I see a gap in her's.
As for mine, it is a G.E brand...and has no gap.
