790.80333310 Kenmore Microwave keeps blowing fuses
AFGUY
Pensacola
I have a, 18 month old Kenmore Microwave model # 790.80333310, which keeps blowing fuses...I have replace all three door switches already, and it worked fine 5 months until this morning, when the fuse popped again...
What else would cause this issue? I think I have a lemon here...It isn't that old 18 months...!!
R Bell
I have replace all three door switches already, and it worked fine 5 months.....
The monitor interlock is a normally closed switch that shorts L1 and Neutral together when the door is open. It might not be the switch causing the problem, but the switch bracket. When you open the door the primary interlock switch opens a split second before the monitor interlock switch, killing the power to the monitor switch. If the latch bracket is broken or worn out or just out of adjustment, and the monitor switch goes first, "pop". Remove power from the machine. Remove the control panel so you can access the door switches. Remove the wires from the switch, one at a time. Check the interlock switches by opening and closing the door.
redwarts
Kansas
I have seen both of the threads from AFGUY on this microwave. I have the same model number, and the same problem. I was going to order switches, but now I am not sure. W
When I plug it in now, the microwave starts running. The display starts flashing, and the microwave starts heating. The light inside doesn't come on, and the turntable doesn't turn. If I push the stop button, the light on the display goes out, but the microwave continues to heat. If I open the door, it blows the fuse.
