FIXED 790.95073310 Kenmore Induction Range Stopped Working
HeidiH
HI
Hahaha, always something! No, we didn't press the light control didn't even think of it. Oops... Thanks, I feel better now. Appreciate your help!
No worries, I'm fairly sure the new power board will fix it.:)
Let us know!
HeidiH
HI
Will do! Unfortunately estimated delivery will be July 14th, so it will be awhile before we can find out. Will keep you posted. Thanks again for your help!
Sounds good.:)
HeidiH
HI
Only Partial Success. �� The Cook top works...I managed to heat water in pot. But the oven and clock display does not. �� So the oven doesn't work either. �� Oven light doesn't work either when I open the oven door. Any ideas? L
HeidiH
HI
The entire center panel stays dark. No beep when powered on. Only display are for the cooktop burners when I turn them on.
HeidiH
HI
Originally all lights worked and it beeped when powered on, but we pressed buttons to set the clock and when we pressed the "start" button nothing worked from that point on...
Are you sure you wired it properly when you replaced the power board?
If so, then that indicates you will need to order and replace the main clock oven control board.
Here it is for your model: 316650011 Controller
HeidiH
HI
Yes it was wired properly, the two connectorized cables only go in one way and we paid attention to how it was wired when removing the old board.
Could it not be the UIB Power Board 316578331 which is right next to the Power Board PS2 that I replaced?
HeidiH
HI
Do you think the UIB is good because the cooktop works? Anyway your website says that the main clock oven control board is out of stock. 😢
Yes, that UIB board only controls the cooktop, so that UIB board is fine.
Yes, Its out-of-stock everywhere I've checked.
HeidiH
HI
Thanks for your help, guess I will just have to wait for it to be in stock.
Yes, that's the only thing you can do for now.
Let us know what you get it.
HeidiH
HI
I found the part on Ebay and they sent it USPS priority mail for free and it arrived in 3 days! Just installed it and everything works, Oven Broiler, Oven Light, Clock and Cooktop! Thank you so much for your time and help with troubleshooting, we could not have done it without your assistance and support. Sorry I couldn't purchase the control board from you since it was out of stock. My friend is a happy camper now with a working Range. Lesson learned, never transport a Range on its back! Thanks again!
Excellent Heidi, glad to hear that.:)
