790.97103010 Kenmore Electric Range taking a long time to reach the temperature. Where to find the model number?
Noraaly
USA
Kenmore Elite Electric Range , Where to find the model number ?All what I see on the use & care guide is 7909710
Added complete model number
Open the oven door and look around the frame. If there's a bottom drawer slide it out and look around that area.
Click here: Appliance Parts
Noraaly
USA
Found it. Thank you
My Range taking a long time to reach the temperature?
Noraaly
USA
Broil element not getting any heat, We replaced it and still not working. Any ideas ?
replace the bake element ?
Not unless it's bad. You need a DMM to check anything. You can pick one up at any of the home centers or Walmart for $20. Start by checking the oven sensor resistance. It should be 1100 ohms at room temperature. Check the voltage at the bake element when the oven is set to bake. The meter should indicate 220 VAC. If not check for 220 VAC across the BAKE terminal and the LINE 2-OUT terminal on the control board.
