SKS123
- 795.72053.118
- Sears Kenmore
- 6-10 years
Hi--
I've been working on my parents' Kenmore Elite 795.72053.118 (actually manufactured by LG) french door fridge (purchased 2013). Last summer (2019) they noticed some odd noises and found their fridge cooling coils were completely iced over, requiring them to manually defrost. They had to do so again in July this year (2020). I was in town 2 weeks ago and began to troubleshoot. Here's what I've found:
Here's another image of the coils from earlier this week, about 2 weeks since the previous manual defrost. But here, the frost seems a bit more uniform?
You can check out the fridge's service manual here, if that helps. I have no hair left on my head, but if I did, I would have torn it all out by now trying to figure out what is wrong.
Do any of you kind folks have any suggestions, diagnoses, questions, anything to help?
Thank you so much!
Sandheep
- All 4 temperature sensors are reading correct resistances (freezer: 9.7k, freezer defrost: 35.2k, fridge: 19.6k, fridge defrost: 19.5k)--note that the freezer sensor's temp/resistance relationship is different from both defrost sensors and the fridge sensor.
- The fridge defrost heater resistance is around 80 ohms, within spec
- the "fuse-M" is reading 0 ohms.
- The defrost heater gets 110VAC for a second or two when the fridge is turned on, as well as when the fridge is in manual defrost mode (test mode button pressed 3 times, fridge display reads "33 33").
- The fridge was last manually defrosted about 72 hours ago. In the last 24 hours, the fridge defroster has been on once for somewhere between 15 and 30 minutes.
- I don't know if the fridge will automatically display error codes or if you have to enter some special mode to see the codes. regardless, I have not seen any error codes on the display.
- The gaskets seem to seal well, they are good about closing the doors, they live in a very dry climate (desert plains, 3200' elevation), and I don't think they excessively put steamy food unsealed food in the fridge.
- There was no issue for the first 6 years of ownership.
- The fridge fan works fine
Thank you so much!
Sandheep
