ridered
- 795.73157.610
- Sears Kenmore
- 6-10 years
I have a Kenmore 795.73157.610 fridge and the water water hose connects to one side and the line into the water/ice despensor on the other side of the water inlet. For some reason the hose popped off the water inlet.
I took the back off and pulled out the water inlet and put the hose back on. Seemed to work for a bit and then I heard the water leaking again.
Why would the hose keep popping off. Is the water intlet damaged. I noticed the clip is just a plasitic clip but does look damaged. The fridge is never moved and this just happened after some number of years.
Do I need to replace the water inlet, or the water hose or could something be blocked in the line. When it is all hooked up the water flows out of the water dispenser fine and it seems to be making ice so not sure it is blocked.
