mcdaniqw
- 795.74025
- Sears Kenmore
- 1-5 years
All,
I have a Kenmore elite 795.74025 with the dreaded LG linear compressor. I purchased it in October of 2017 and it died on valentines day of 2021.
I had a sears technician come out, and they confirmed the compressor had failed. For $550, Sears replaced the compressor with the new Universal compressor, and they flashed the PCB to update the firmware. Within 24 hours, the refrigerator was completely dead. No lights, no nothing. After confirming power at the outlet, I did a continuity check on the PCB board fuse and the fuse was blown. I'm trying to get Sears to replace the PCB free of charge, but they are saying it's not covered under there guarantee, because the initial repair was only for the compressor, even though they modified the PCB by reflashing it.
They are blaming it on the fact that I have a fridge and a deep freeze plugged into the same outlet in the garage. They said that the compressor of the fridge and the freezer likely turned on at the same time causing a spike to blow the fuse on the fridge. The deep freeze is rated at 5 amps and the fridge is rated at 3 amps. The house circuit is a 20amp circuit. I told that I realize that the compressor would cause a spike in current temporarily, but that would blow the breaker to the house circuit, not the fuse in the fridge. Knowing that the 2 appliances are in parallel and doing V=IR.... basically I come up with that the current going through the fridge is = 120V divided by the Resistance of the fridge. So the Freezer current should have not impact on the fridge... correct?
Has anyone else had a PCB go bad shortly after a tech updated the firmware on the PCB for the new universal compressor. The PCB board is EBR838069
