795.77563600 Kenmore Elite Refrigerator Er 1F
Sterling
We have the error code "Er 1F" on the front of our fridge. After researching, it seems most people had issues with ice buildup in the bottom of their freezer and on their fan. I had no ice build up and my fan seemed to be working fine.
I have also read that this error comes up if the connection to the fan is lost for more than 115 seconds but I do not know how to check that. All diagrams I have found are not detailed enough or too small to read.
The water dispenser still works. I initially turned the ice maker off because water was dripping out of the dispenser. I have since turned it on to see if it will produce ice. While I was attempting to work on it water came out of the valve to fill up the ice molds so I do not think that is the issue. I will check it later for ice. If there is no ice or water in the molds I will put water in to see if ice is produced but it seems like if it does what it did previously there will be water in the molds but no ice formed.
Any tips would be greatly appreciated. Thank you!
