FIXED 795.78773800 Kenmore elite fridge making clicking noise
lbb
I have a 10 y/o Kenmore Elite model 795.78773800 fridge.
Recently, it started making a clicking noise, apparently (as close as I can tell) from the lower rear half of the fridge. There is no other noises, the compressor seems quiet and the fridge is otherwise working totally fine.
From the forums I have found two suggestions, which I would not mind trying, but I ran into difficulties when I was about to get the parts:
1. It could be the Compressor Start Relay. Seems reasonable but I cannot find a part for it that matches my model fridge. According to appliancepartspros.com, it could be integrated into the Power Control Board Assembly, but I am not too sure.
2. In the forums here someone had similar problems with their fridge, and it was the Defrost Timer. However, just like a before I have a hard time finding the part.
Now, it could be that I am extremely bad a part name searches. I honestly would appreciate any help on finding the correct part number for these or really any workable suggestion.
How often does it make those clicking noises?
Can you pinpoint it? Pull the refrigerator out from the wall, then remove the rear lower back access panel and see if the clicking is coming from the compressor.
lbb
When I hear it happen I hear the compressor go. But I will follow your suggestion tonight and try to hear it with the panel pulled off. I'll post an update tonight.
Ok, sounds like a plan.:)
lbb
Hello,
Sorry for the day's delay, I couldn't get away from work. So I sat behind the fridge and found that this (I think it's a relay) is the one making the clicking sound. I am 99% positive ha ha.
Here is the picture of it. I have tried searching for a replacement online but cannot find one. If you know of any suggested alternatives, please let me know.
Thanks.
Yes, this one:
Start Device CLS30820001
Make sure you unplug the refrigerator from the wall outlet first before replacing it.
Blue wire to N
Black wire to L
lbb
Thank you so much, I wouldn’t have been able to find it. I even ordered a used part on ebay. But I’ll keep that one aside.
Ok, let us know how it goes after you replace it.
lbb
Absolutely! I might be asking more questions ha ha.
Still not too sure on what the N or L is in "blue wire to N" or "black wire to L" I am hoping it's self-explanatory once I got the parts in my hand!
Yes, when you get the new part you will see each wire terminal on the part, one is labeled L the other is labeled N.
lbb
Hello,
Finally, I got to work on it. I just finished installing it. Matching the cables was easy enough and it seems to slip in right in place. I just plugged the fridge back in, so hopefully, it will be working back soon.
This is a “before“ picture
and this is the new part:
It looks like it is upside down but it appears just to be a physical configuration change.
I'll post an update if something else is comes up.
Looks good, did the compressor start running when you plugged it in?
Is the freezer side getting super cold now? Refrigerator side getting cool now?
lbb
When I plugged it in, it seemed to be turned on. I don’t know much about it, but it did vibrate as one would expect.
The fridge kept running fine. It wasn’t failing due to cooling. I replaced the relay because the old one kept clicking.
I am a little paranoid because, previously, I had purchased a bad start relay. This one doesn’t make any clicking noise, the compressor vibrates like it’s running, so hopefully it continues to work just fine!
quick edit: by vibrate I don’t mean shaking or anything abnormal, rather a subtle vibration/rumble.
Ok, got it.:)
Thanks for clarifying that.(y)
