Dfrance777
- 795.79783902
- Sears Kenmore
- 6-10 years
I would appreciate any assistance in troubleshooting and fixing this issue.
I have a Sears Kenmore Elite three door fridge model 795.79783.902. It has ice and water in the door. The water in the door works and dispenses water with good pressure and switches to dispensing ice if there is any ice in the ice storage bin. It is not producing ice unless I manually fill the icemaker with water. If I do fill it - it will make ice and dump it but does not refill with water. The icemaker model # is AEQ36756914. The water inlet valve is #AJU72992601- it only has ONE solenoid. The water supply comes from the wall of the house into the water inlet valve - out the valve as one white tube and runs up the back of the fridge to the top and into the fridge and a blue tube come out the same hole at the top and connects to a short white tube that goes back into the fridge at the top in a separate hole just a few inches away.
If I disconnect the blue tube and press the water glass fill switch in the door water comes out the blue tube so this is obvious the supply line for the water in the door that connects to the white tube and leading eventually to the valve in the door to dispense water. There must be some type of T or valve within the upper part of the fridge that sends water to the icemaker? What I haven't figured out is there another solenoid somewhere in the fridge on the water line after the first fill valve that controls water to the icemaker? With only one water supply line from the fill valve at the bottom of the fridge with one solenoid that connects to the water supply line from the wall wouldn't it have to turn on when the switch for water in the door is pressed and again when the icemaker calls for water? If the solenoid or valve opens to dispense water wouldn't that mean it should dispense water to the icemaker when it calls for water? Or is there a second solenoid somewhere else that the icemaker sends a signal to when it needs water to fill the icemaker that is not working? Where is it located? How does one get to it to test and/or replace?
Any help you can provide is much appreciated. Thank you.
