796.41262610 Kenmore Washer - Fabric softener not dispensing
mjorrin
FL
LG built kenmore washer won't dispense softener. Tested water valves with cheaters cord and all have good water pressure. Is the dispenser assembly bad ??
I don't have the tech. data sheet for this model, but it should be located inside your control console.
Once you locate it, run the diagnostics to see if the dispenser is bad or not.
mjorrin
FL
No option to run water to the softener dispenser on service manual but it seems like there is a flap inside the disp assy that is stuck.
I ordered the disp assy, will update after it arrives.
