FIXED 796.41682.610 Kenmore Elite Washer making noise
Leon R
Massachusetts
Our 3 year old washer started making LOUD noise! It appears to spin just fine, but then the noise starts! I thought it was coming from the drain pump (and I am focusing on it in the beginning of the video). But the noise seems to be coming from the back of the machine.
Any ideas? TIA!
Yes, I heard it.
So this only happens during the wash cycle? Not the spin cycle?
With the tub empty open the door and turn the tub with your hand both ways and see if it grinds either way you turn it.
Leon R
Massachusetts
it is definitely doing this during the wash cycle, I haven’t allowed it to go any farther to see if it will also do it during the spin cycle.
The drum spins perfectly smooth!
Ok, I'd pull the washer out from the wall, then unplug it, then remove the back access panel and check the rotor, to make sure its tight and that its NOT cracked or broken.
This Kenmore 796 model is made by LG.
Here's the rotor for your model:
AHL72914401 Rotor Assembly
This video gives you the general idea of how to remove it and replace it:
Leon R
Massachusetts
Jake, I think you are onto something! Thank you! Looks like my rotor was banging against the cover!
Do you think the rotor is actually bad? Or is the drum allowed to swing more than allowed?
Interesting, is that rotor nut tight in the middle of it?
Run the spin cycle with NO CLOTHES in it, with that cover off and see what happens.
Leon R
Massachusetts
I think I found the problem! I believe that the cover, which is unbelievably flimsy, got bend in by the hoses until the rotor stared contacting the cover! I was able to bend it back out with very little effort!
Any advice on trying to avoid it in the future?
Thank you!
Excellent Leon, good job.(y)
That I don't know, never seen that happen before. Maybe take it to a metal shop in your area and ask them if they can reinforce it.:)
Leon R
Massachusetts
Thanks, Jake!
I am a mechanical engineer, so reenforcing things is pretty natural for me. I used some scrap metal I had in the garage, along with some 5 minutes epoxy and made the panel MUCH stuffer! I doubt I will have this problem again ;)
Oh, and the noise is gone!
Yes, I saw your video. It looks very solid now Leon.(y)
Yes, that should keep it from happening again.
