Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Whirlpool Duet WED9200SQ0 code F70
  1. #11
    Jul 2007
    alabama
    Default duet combo
    hi ya Jake, looking into the duet washer/dryer combo to replace my whirlpool set, hubby says u better make sure this is what u want cause if it ain't the next time i wash clothes will be at the nearest Laundromat so is this the best washer/dryer combo on the market for my money and reliability wise ? gotta be able to wash and dry king size quilts and comforters when needed. hubby says i don't want to hear no bitchin bout it wont work or the peice of crap anything know what i mean. ok guess thats the deal. well thanks for ur help, brenda
  2. #12
    Yes, The Whirlpool Duets and the Kenmore HE3 models have been reliable.
    I tell my customers if you buy an electronic washer/dryer to always get the extended warranty for at least 3-5 yrs.
    Nov 2007
    Dayton, Ohio
    Default Duet F70 Error
    We purchased a Duet set recently. Our first load in the dryer resulted in an F70 error. I called the store and they replaced the whole set. First load in the new dryer, F70 error. In the end, it turned out we needed to have our dryer duct cleaned professionally. The sensors in the dryer are very sensitive and picked up that there wasn't enough airflow through the vent. After we had the duct cleaned, everything is working perfectly.
  4. #14
    Jan 2013
    VA
    I have had the same problems since I bought this dryer. Seriously not impressed.
    Right after I bought mine, about 3 years ago now started doing the F70 thing on me.
    I worked around it for nearly 2 years....Checked the Vent( Had the Chimney sweep do this), was totally clear, turned the dryer off a number of times, at the breaker for 30 minutes or more, that didn't help. It would flash F70 on me, even if I hadn't used the thing in a couple of weeks.
    Paid to have an Appliance Tech change out the two companion circuit boards. Everything seemed find after that.... until......
    The last few months, it has been showing the F70 again... doing everything I did above.... and again, even if I haven't used the dryer for a couple of weeks....it keeps coming on and flashing the F70.
    Since I have had the two main boards replaced, what else do I need to do to finally get this thing to work right?
  5. #15
    Quote Originally Posted by ShariN View Post
    We would need the model number of your dryer.
    Click here: Appliance Parts at RepairClinic. 125 Brands. 365 Day Returns.
    Then you will see a link that says: Help me find my model number.
    I'm attaching the tech. data sheet for the Whirlpool Duet Dryer, read on page 3 where it lists the F70/F71 error codes and follow what it says to check.
    Attached Files Attached Files
  1. FIXED: Whirlpool Duet WED9200SQ0 Not powering up
    By jim601 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 8th, 2014, 01:42 PM
  2. FIXED: Duet WED9200SQ0 Heater Element Replacement
    By usnbostx2 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 9th, 2013, 05:13 AM
  3. F11 code on Whirlpool Duet
    By ericruuska in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 11th, 2013, 10:11 PM
  4. Whirlpool Duet F11 code within first 30 sec
    By neubaum in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 15th, 2009, 04:49 PM
  5. Duet WED9200SQ0 Service Manual. Same manual as the one sticky'd above?
    By 5thcorps in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 24th, 2008, 08:15 PM
