mdevincenzo
- 970-437136
- Sears Kenmore
- 6-10 years
I was having issues with the lower oven burning food and discover that the broil element was always on when the I turned the oven on. It did not shut off when it reached temperature. I exposed the control board and the relay board hoping to find a fused contact on the broil relay. I found nothing, after I turned the power back on it started to work normally and the oven reached the proper set temperature, but it did not display the temperature on the circular analog temp display. I had and external thermocouple in the oven and that's why I know it was working. I check all the connection on the control board, specifically the temp read out connectors and they all seem fine. Both ovens work fine, but neither displays the temperature. Any idea what is happening?
