DisasterDan
- 970-660130
- Sears Kenmore
- 6-10 years
Good Day Everyone, I have a Kenmore Elite 970-660130 Induction Range. It initially started acting up about two months ago with error code E037 while using the induction cooktop or the oven. I tracked down the issue to a left induction generator (part# 316304300) and replaced it. The induction cooktop then worked great but could not get the oven to run. I check the resistance on both oven elements and the heat probe, and both worked. I then replaced the oven control board (part# 316577099). I am now getting error code E037 again when I try to use either the cooktop or the oven. I have tried switching the two induction generators to see if I could isolate the issue, but it resulted in the same error code.
At this point I am flummoxed. I am suspecting that it is a wiring issue but would like some thoughts on what I should be checking next. I am under a bit of pressure to get this range fixed.
