Jeff_G
- 970-687623
Oven now takes extremely long to pre heat. Previously would take 15 minutes to preheat to 350 degrees. Now it wil take 45 minutes and only get to 233 degrees. The display box shows a solid red line on the bottom for 50 seconds then a broken red line on the top for 10 seconds.
I have done the following troubleshooting.
Power - The stove top burners work as normal. They heat up within seconds. I read that this means the 240V power coming to the oven is OK. I did switch off the circuit breaker and turn it on again but it made no difference.
MultiMeter - I checked the Baking element for resistance (approx 16 ohms) and the Broiling element for resistance (approx 14 ohms) and the Temperatiure sensor probe for resistance (approx 1080 ohms).
I have visually inspected the control board and did not see any damage, however I am not an expert and not sure what I am looking for.
I am hesitant to order a control board because of the cost and the fact that I cannot return it once I open the package and install it. Anyway to confirm the control board is the cause, or any ideas of what else may be the cause?
