970C85353310 blowing fuses when not in use.
belgiangenius
Toronto
970C85353310
For the past six months or so, we would occasionally go to use this microwave and notice that it was dead. It would trip the breaker on the breaker panel when not in use.
Then three weeks ago, the microwave was again dead. It was not the circuit breaker but the internal 20A fuse, which I replaced.
Now, three weeks later, same thing. I just changed the fuse again.
This microwave works perfectly fine. The fuse blows when it's not in use!
I'm sorry but I've never heard of such a case. Usually the only time the internal fuse would blow is when the high voltage circuit was energized (ie. when trying to cook). Also, a problem in the microwave would usually blow the internal fuse not trip the house breaker.
Try putting something meltable into the oven when not in use and see if it is affected the next time the fuse blows. That might indicate if the HV circuit was indeed being powered, to help narrow possible causes.
