Access impeller housing?
DIY Guy
Midwest
I have a 1 year old Maytag washing machine (SAV3655AWW) that has a noise coming from the impeller housing. I think it is a bobby pin stuck in the housing. What is the best way to access the impeller area. There appears to be access through the bottom of the housing??? I removed the drain hose but the housing has a long neck and I really can't get to the problem. Any help would be appreciated.
Kevin T.
DIY Guy
Midwest
Thanks Mac, I just found out also from the Dick VanDyke parts guys the pump is not serviceable. I'll just have to try to grab it with a long pair of needle nose plyers through the discharge port??? Or like you said, buy a new pump.
Thanks Gentlemen
Kevin
