airplanenut
- WSF26C3EXF01
- Whirlpool
- More than 10 years
The ice maker in my Whirlpool side-by-side is no longer producing ice, and after taking it apart and doing what I can, I'm 99% sure the issue is a significant blockage in the waterline somewhere in the freezer door. As I've tried to fix it, I've noticed the following:
-There is ice buildup on the guide that takes water from the waterline into the ice maker, and if I remove the ice, it will be back within hours or a day. That tells me a small amount of water is flowing, but not enough to make ice cubes.
-If I manually fill the ice maker with water, ice cubes will be made and sent to the ice bucket, which tells me that the ice maker itself is working.
-I disconnected the waterline at the bottom of the freezer door and waited for water to pump, and it did just fine, so I don't think the issue is with anything before the door (the water dispenser is also working just fine).
Thinking that the issue is a blockage in the waterline, I got a 3' frozen waterline tool, but couldn't get it to work. From the ice maker itself, I don't have leverage to thread it into the waterline (the hole at the end of the line points up and is a few inches from where my fingers can reach; I can't get the tube to turn 90 degrees and go down the hole).
I tried squirting a lot of warm water into the top of the line, but most/all just dribbled back down (and made a mess) so clearly I didn't send a significant amount--if any--down the waterline to the blockage. I also threaded all 3 feet from the waterline connection at the bottom of the door and injected warm water numerous times, but to no avail. This makes me think the block is somewhere more than 3' up the line in the door.
What I can't figure out now is what else I can try to unclog this. I can't find a waterline clearing tool with a longer hose (the door is around 54", so I'd need a ~6' line to go the whole way), and am not sure what else I may be able to thread up there which could either inject warm water (I'd have to make a waterline tool myself) or otherwise provide some friction to break apart the ice enough that it gets removed (perhaps something like a really thin snake you'd use to clean a brass instrument).
Any ideas? I'm not particularly handy and am pretty satisfied with myself for (seemingly) getting close to determining the problem, but I'd hate to be at a point where there isn't some cheap fix and I need to make a service call.
