Admiral Dryer Not Drying AED4675YQ0
troye
Biloxi, Mississippi
AED4675YQ0
Admiral
HI, the dryer would go through its cycle but the items were not dry. I replaced the following below parts. The dryer worked and dried clothes for 3 loads but now has stopped heating again.
Any idea of what I need to replace? Thanks!
1 x 279838 dryer heating element
1 x 3977767 dryer thermostat
1 x 3387134 dryer thermostat
1 x 3977393 thermal fuse
2 x 3392519 dryer thermal fuse
Are those OEM parts?
If the vent is clear and clean you will need to take the dryer temperature--->WITH NO CLOTHES in the dryer--->With the dryer on timed dry, high heat, the temperature at the dryer vent should be 160*F to 190*F. Watch the thermometer or multimeter display and note the temperature the element turns off and the temperature it turns back on through about 6-8 cycles. They should be fairly consistent.
My multimeter reads temperature, it comes with a probe you put in the dryer door. WITH NO CLOTHES in the dryer--->Just open the dryer door and insert the probe, then close the door and run the dryer and watch the meter. Don't put the probe to far in or it will be hitting the drum as it turns.
