FIXED Admiral washer LNC6760B71 snubber
rbrown1946
Indiana
LNC6760B71
Admiral
Need some advise on how to change the snubber. Does the transmission need to be removed? What tools will be needed and is there a way to avoid buying the brake removal tool?
You can change the snubber alone.
Here's the snubber for your model(Video Included):
WP21002026 Snubber Ring
Watch the video in the part link and do everything exactly the way he does it.
rbrown1946
Indiana
Thanks for the info. I was able to get the snubber out without a brake tool. I replaced the shorter screws one at a time with longer screws. I then backed out the longer screws evenly until the pressure from the spring was released. When I installed the new snubber I used the longer screws to depress the spring evenly. Then I replaced the longer screws with the shorter original screws. Worked well and saved some money.
Thanks again.
Excellent good job.:)
