FIXED AEE24DTH1 GE Air Room Air Conditioner won't keep compressor running and cool light flashes
mpkozar
United States
AEE24DTH1
This AC unit is driving me crazy. I'm using a CoolBot and this AC unit to cool a cold room. The CoolBot has a heater that "trick"s the AC units temperature probe into thinking the room is colder than it is. After resetting the AC the compressor will turn on but after a few minutes the "Cool" light starts flashing and the compressor kicks off. There is no way the unit is icing - it won't stay on long enough for that to happen! I also tried it in "Energy Saver" mode and it does the same thing except that I can easily tell the compressor is off because the fan turns off too.
This unit is only 2 years old and when the compressor runs it blows plenty cold. According to the infrared thermometer it gets down to 26 degrees F.
Any help would be appreciated.
mk
Unfortunately I don't know what a coolbot is. Will the unit run without it? In other words, if the unit was in a warm room will it operate normally?
mpkozar
United States
Thanks for the quick reply. It does the same thing without the CoolBot. If I use a heat gun on the lowest setting to heat up the thermometer sensor it will run initially and then kick off the compressor and "Cool" led will flash. I also took a brush and ran it over the fins on both inside and outside of the unit and still didn't help.
mk
mpkozar
United States
I figured it out. It turns out that this model has a secondary sensor or tube temp sensor that was interfering with the CoolBot. Since the unit was installed in 2016, I just assumed it was installed correctly.
Thanks for the quick replies. This forum is so helpful.
Best,
mk
I wasn't much help but I'm glad you got it figured. Thanks for posting the update!
