You have that backwards, it should be--->F2E1 Shorted keypad. I'm attaching your tech. data sheet below.
1. Unplug range or disconnect power.
2. Inspect keypad connection to main control (P11). If connection is loose/unplugged, reconnect.
3. Replace all parts and panels before operating.
4. Plug in range or reconnect power. Allow 60 seconds for main control to identify keypad. If error code reappears, go to Step 5. If the error code does not reappear, go to Step 9.
5. Unplug range or disconnect power. Inspect keypad connector (P11) to main control for sign of damage (cracked, ripped, etc.). If damage is found, go to Step 8.
6. Replace all parts and panels before operating.
7. Plug in range or reconnect power. Allow 60 seconds for main control to identify keypad. If error code reappears, go to Step 8. If the error code does not reappear, go to Step 9.
8. Replace components in the following order of likelihood of failure:
a. Keypad
b. Main control
9. Replace all parts and panels before operating.
10. Plug in range or reconnect power.
11. Verify operation is normal. Enter Diagnostics mode and verify that there are no error codes.
On this model the keypad and Main control are 1 unit:
W10906760 Cntrl-Elec
