AEW10AQQ1 GE AC Unit blower motor replacement
Maverick923
AEW10AQQ1
I have been searching for a replacement blower motor for GE AEW10AQQ1.
I am unable to find the motor everywhere I have looked.
At this point, I am trying to locate a suitable replacement.
Other then amps, and volts, I am not sure what values are most important when searching.
Some advice would be greatly appreciated.
Thank you in advance!
I found it in Venezuela. This is the number: CJ75W (YY095-954PL02-002) .Try to locate a Johnstone Supply or Granger in your area. Take the old motor with you so they can match it up. Important- shaft diameter and length, mounting , motor single phase, 3 phase, 4 phase, hp, voltage.
Maverick923
Doing a google search, I found what you found. I did that way before. I contacted Granger, but it was not a store. They could not help me because the label does not display the horsepower.
How can I find that or any other info if not on the label?
I did a search on Bing and yahoo. I found GE WJ94X10333 which seems to be compatible with AEM10AQQ1. That is a very close match. I wonder if the 3rd letter tells which retailer the unit was purchased from. Am going to get with Johnstone and see what I find anyway.
That might be a difficult motor to match because it's 120 VAC 4 phase. I'm not 100% positive but I think most 3 phase and 4 phase motors are 208V.
That should be able to be calculated (roughly anyway)
Which came up with .168 HP at 85% efficiency which is 1/6 HP (.16667).
Maverick923 said:
I found GE WJ94X10333 which seems to be compatible with AEM10AQQ1. That is a very close match. I wonder if the 3rd letter [of the model number] tells which retailer the unit was purchased from.
That's a good thought! I don't have a current GE A/C service manual to see if it shows their model number nomenclature.
I couldn't trace any of the numbers on that motor tag to any manufacturer's part number. :(
Are there no other numbers on it?
Maverick923
Unfortunately, I was not able to see any other numbers, but BW135. The motor has rust much surface rust all around. Thanks for that other info, it may be just a little easier to find a suitable replacement.
