tonylo
- AFI2539ERM
- Amana
- 1-5 years
Mod #AFI2539ERM side by side Amana. With the exception, "no water flows into the ice maker" the ice maker cycles function properly . Water flows to the water dispenser at normal pressure. The water valve for the ice dispenser was replaced and the continuity on both of its circuits tested good.
I tried to remove the ice maker to check the water flow tube for ice, the ice maker would not dislodge from the track its locked into.
Is there another way to check the tube?
Can the flow problem be something other than a frozen supply tube?
Is there another way to access the tube?
Can the circuit board be causing the water flow problem? Is there a way to check the board?
Tony
Tony
