AGQ8700FS1 Frigidaire Affinity Gas Dryer not heating, shutting off mid-cycle, three blinking lights.
TrevanM
Los Angeles, CA
AGQ8700FS1
Frigidaire
Our dryer started doing this while I was out on a work trip and am just not starting to trouble shoot.
If anyone. can help with some basic trouble shooting steps or If anyone could help me with a tech sheet/ how to get into diagnostic mode, it would be appreciated.
All the best!
There is a routine to gather the fault codes from the machine which might indicate the problem area to focus on. The attached 'tech sheet' from a slightly different model dryer should describe how to recover the codes from your machine. (There should also be a paper copy of the instructions inside your dryer.)
If you post the fault codes you recover here we might be able to suggest a curse of action if needed.
  • AGQ6700FS2 Tech Sheet with 137058200 wiring.pdf
