AGR5630BDB1 Amana oven problems. No spark ignition bake or broil.
John B88
Illinois
AGR5630BDB1
Amana
Hello,
I have an Amana AGR5630BDB1 oven and for some reason the oven and broiler's spark ignition does not activate. The stove top burners ignite without any issues. The gas is on and the oven is only about 4 years old. I ran a diagnostic on the display and it did not give me a code. I believe it read CLR which according to the manual was ok. Any help would be greatly appreciated.
John
Hi John,
I asked our other tech bigbuck if he has the tech. data sheet for this model, because we will need that to determine the problem.
Thanks bigbuck!
Look on Page 6 where it says DSI board, check those voltages in that chart when your bake is ON and broil is ON. Also check to make sure you are getting 120 volts to the DSI board.
John B88
Illinois
That really helps! I really appreciate the information. I will see if I can figure it out. Very much appreciated
Ok John, sounds good.
