All sorts of problems with my kenmore elite 795.72483.410
jaguars4r
Chicago
So this Fridge is barely 2yrs old and since last week, ive had all sorts of problems with it.
1. The ice maker doesn't rotate and drop the ice unless I press the bottom reset button and then it'll rotate and drop the ice (I figure the sensor is bad)
2. Then the same day, the freezer start getting warm and food is slowly all melting
3. Then 3 days later, the fridge is now getting warm and it can no longer make ice, since nothing gets cold enough.
Absolutely insane that im having all these problems and its still pretty much new. Anyone experience the same issues?
Not cooling properly
2. Then the same day, the freezer start getting warm and food is slowly all melting... Absolutely insane that im having all these problems
It sounds like you may only have ONE problem, not cooling properly. There is a thermostat in the icemaker that prevents its operation if the freezer temperature gets too high. That point is well below when food would actually start to melt so that would one of the first signs of a temperature issue.
Someone will need to look into the cooling problem. Some possibilities are described at the following link.
LINK > Appliance411: FAQ: My frost free refrigerator is not cooling properly. What might be the problem?
www.Appliance411.com
=D~~~~~~
jaguars4r
Chicago
Had a tech come today it the fridge is junk. Yoder Condenser Loop is my issue. Good thing its covered by the warranty. Thank you.
