FIXED Amana ABB2223DEW Only 30v ac during force defrost AND sevice test mode
djbrown
kimberly oregon
ABB2223DEW
Amana
Only 30v ac during force defrost AND service test mode.
the control board, defrost thermostat are both about 2-3 mo old.
the defrost heater ohms out at 29-30 ohms.
the service test mode was able to function all other functions.
this was the original problem when I replaced the control board a few mo. back . I did NOT test the voltage when I installed the new control board.
SIDE NOTE: I have replace the control board 3-4 times over the refrigerators life.
im not sure if there is another part that I am not aware of.
help would be grateful
You must have a short in your wiring, that's all it can be at this point.
Check every inch of your wiring harness and look for frayed or broken wires.
djbrown
kimberly oregon
thank you for the reply ,
I have looked for a loose connection or chafing, ill look again and let you know what I have found.
Yes, that's got to be the problem, take your time and check the all the wires carefully. Start from the back of your refrigerator, pull the refrigerator out from the wall and check the wires in the back where the power cord connects to, I have seen shorts in the plastic wire connectors as well, especially on the older Amana brand.
djbrown
kimberly oregon
i wanted to update this incase someone has the same problem . after cleaning all the connections I could easily see and cleaning what grounds I could find. I still had the problem of not defrosting. I started taking the whole fridge apart (I was going to strip it down to nothing and start over) I found one more connection above the jazz board location. I cleaned the contacts and plugged the fridge back into the wall. now going on a few month its working perfectly ,
thank you for the help.
Excellent good find. (y)
For others following your thread and need to know what the JAZZ board is I'm posting it below for your model.
Here's the JAZZ BOARD for your model:
Main Control Board WPW10503278
There's a video in this link that shows you how to access/replace it:
WPW10503278 Electronic Control Board
